Unity 5.X Global.asa: hr=0x80040154)
Aug 8th, 2008
Hi all,
I installed CU 5.X and when i click cisco unity systemadministration page it shows
Server.CreateObject(AvSaLocalization.AvSaLocalization.1) failed.
This is most likely an error with a DLL, probably AvSaLocalizationSvr.dll or perhaps AvSaLocaleInfoSvr.dll.
Check that these files are present, and registered with REGSVR32.
Also be sure that the appropriate MsgStoreRes.dll file is present.
Cannot continue.
(From: Global.asa: hr=0x80040154)
i followed the troubleshooting steps by cisco as mentioned here http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a00801651f9.shtml..
at the final line it says that the two services AvCsgateway & AvDsGlobalCatalog must also be registered with reg32sr.. but i dont find any dll for those two services.
What i have missed or i need to re install unity once again to get those 2 dll's.
