verify flash: on C3750.. file not found
Aug 8th, 2008
Why I can't verify IOS bin file saved in a subfolder on the flash!
verify flash:c3750-ipbasek9-mz.122-44.SE2/c3750-ipbasek9-mz.122-44.SE2.bin"
%Error verifying flash... (No such file or directory)
Overall Rating: 5 (2 ratings)
vijayasankar Fri, 08/08/2008 - 03:55
It looks like some typo in the command.
the command should mostly look like
"verify flash:c3750-ipbasek9-mz.122-44.SE2.bin"
Check this out.
-VJ
lcolimoro Fri, 08/08/2008 - 04:40
I tried already all the combinations!
I also tried it to run on different 3750 switches and I had the same unsuccessfully results. It seems the "verify" is unable to read an image file under a subfolder!
vijayasankar Fri, 08/08/2008 - 06:15
Try this..
1) issue the cd command to switch to the directory you want
cd "directoryname:
2) Execute the verify command with the file name.
verify "filename"
Alternatively you can try this alsow
verify flash:/directoryname/filename
Have a note of the slash "/".
In your case it should be as follows
verify flash:/c3750-ipbasek9-mz.122-44.SE2/c3750-ipbasek9-mz.122-44.SE2.bin
This should work.
Test this and let us know the result. Both method works for me.
-VJ
lcolimoro Sun, 08/10/2008 - 21:44
I still don't get verifiy worked on the ones that have been upgraded to c3750-ipbasek9-mz.122-44.SE2.bin
See the attached file!
I have several c3750 and the verify works on the ones running ipbase-mz.122-25.SEE2.
Is it a bug of 122-44-SE2 version?
lcolimoro Mon, 08/11/2008 - 21:32
I have few switches in the stack. The ones I tested are not configured as stack.
I have tried additional test while I'm writing this email and it seems the problem only occurrs with the 3750s running /c3750-ipbasek9-mz.122-44.SE2 as IOS image.
I tried some other which are not yet updated with latest IOS and the verify command works fine!
It must be a bug for that IOS version!
prasetiohadi Thu, 12/05/2013 - 16:12
Hi, I got the same problem, and I try to put extra parameter  /md5
example :
verify /md5 flash:/c3750-ipbasek9-mz.122-44.SE2/c3750-ipbasek9-mz.122-44.SE2.bin
and it's work for me.
Jean Matthew Thu, 12/22/2011 - 03:16
Hi, getting the same error message with c3750-ipbasek9-mz.122-53.SE1.bin
Cisco#verify flash:c3750-ipbasek9-mz.122-53.SE1.bin
File system hash verification failed for file flash:c3750-ipbasek9-mz.122-53.SE1.bin(No such file or directory).
After getting MD5 hash value for that IOS (http://www.cisco.com/cisco/software/cart.html?mdfid=&treeMdfId=268438038&flowid=null&addoption=DN&imageGuId=717943AADCA8210CC4125BFAF81514BC75E2C617&isLatestRel=)
I can now succesfully proceed with
Cisco#verify /md5 flash:c3750-ipbasek9-mz.122-53.SE1.bin 7fd986e52367ca1153d6103edf8bd4ed
................................................................................Done!
Verified (flash:c3750-ipbasek9-mz.122-53.SE1.bin) = 7fd986e52367ca1153d6103edf8bd4ed
That's all
