CUOM 2.03 incorrect service level view.
Aug 8th, 2008
Hi to all,
I would like to know if some one has encountered the some problem before, i use CUOM 2.03 to monitor voice equipments. The problem that the topology is not correct: 1 server appears twice in the IPCC group.
ebreniz Thu, 08/14/2008 - 06:40
There are issues seen within the CSV files that are preventing the data from being collected. Can you get the csv file associated with whatever device you are trying to use Performance Tool on? The csv files are located \cscopx\data\gsu\_#GSUDATA#_
The folowing URL will help you:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_unified_operations_manager/2.0.1/user/guide/usePAD.html
