Problem between 6500 and voice module comunication
Aug 8th, 2008
I'm configuring a Cisco Comunication Media Module on Cisco 6500. I have this module on slot 3 hence i must configuring gigabitethernet 3/1 on router, I do next:
1. enable
2. configure terminal
3. interface gigabitethernet 3/1
4. switchport
5. switchport access vlan 102
6. no shutdown
7. end
Next step i configure on gateway gigabitethernet next way:
1. enable
3. interface gigabitethernet 1/0
4. ip address
5. h323-gateway voip interface
6. h323-gateway voip bind srcaddr
I configure ip subnet-zero and
ip route
* corresponding to HSRP interface on VLAN 102 with network
Problem?? When i do sh ip route gw doesn't show static route and with ip subnet-zero doesn't show in sh run. CDP is enable but nothing appears.
I have a 4500 series with voice module and the method is the same and works fine but with 6500 no.
Any ideas???
Thanks a lot
picledo123 Fri, 08/08/2008 - 08:03
Thanks for response!
I knew this link but is not my scenario, in this example on router has 1 gi and 4 fast on CMM module( as same as me) but on CMM module i've only on gi and zero fast.
Marwan ALshawi Sat, 08/09/2008 - 03:47
The CMM provides Layer 2 forwarding only; if a packet needs to be Layer 3 routed, the packet is
forwarded. Therefore, you must enable ip routing and specify a static default route to the gateway
try to put in global config mode:
ip routing
picledo123 Sat, 08/09/2008 - 15:53
i tried with ip routing wihtout results. i've upload my gw config in this config see that doesn't appear ip subnet-zero but i'ver load in.
And this is my "sh ip route", notice that my default route doesn't appear.
GW#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C is directly connected, EOBC0/0
Marwan ALshawi Sat, 08/09/2008 - 18:03
the config mostly sounds good !
by the way i havt seen
ip classless
in ur config
try to add it
ABOUT ur Switch have u made SVI for vlan 102 ?
if not u have to as the following
interface vlan 102
ip address
no shut
if u didnt make this SVI the problem from here ofcourse
and let me know
good luck
picledo123 Mon, 08/11/2008 - 00:42
I don't understand you, SVI??
switchport voice interface?
I added ip classless but on sh run don't show it
Marwan ALshawi Mon, 08/11/2008 - 04:06
ok cool
ip route
the IP address of what?
this IP must be the IP addres of the vlan 102 interface according to your config
so in the
switch if u use 6500 with ios softeware
remove th hsrp now just check the connectivity with the switch first
and after removeing the hsrp
do the foloiwng
interface vlan 102
ip address
no shut
this will be the switch virtual interface SVI
and will be the default gateway for the CMM
if u do show ip route on the 6500 not the cmm
u see the as a directly connected network
after that the show ip route on ur CMM acording to ur config should work
do it and let me know
good luck
