DMA Warning Messages
Aug 8th, 2008
I have run DMA 6.1 on my CCM V4.1(3) Publisher.
I have received 6 Warning messages in the warning log file.
All warnings are related to the TelecasterServiceParameter.
eg Warning message (Business Rule Violation): TelecasterServiceParameter Description has invalid format. It should contain letters, numbers and some special characters. Max length is 500. Regular expression used to validate:
Can anybody advise on a fix for this issue. I have attached the full log file.
I can find the entries using Query Analyser.
thanks
Ian.
testeven Fri, 08/08/2008 - 12:08
Hi!
I've seen these type of warnings when customers have a customized IP phone service with a customized parameter and description of the parameter.
Probably in the description, there are some invalid characters which do not meet the requirements of INFORMIX database. But these invalid characters in the description will be automatically ignored during database migration. The IP phone services will be migrated anyways.
There was a bug: CSCsc43691 "Data Dictionary does not allow ampersand in telecasterserviceparameter"
Please check the telecaster configuration (user, description, etc) does not contain any invalid character.
Hope this helps :)
