Need to dial 4 digit 04xx without getting operator
Aug 8th, 2008
I currently have a translation pattern 0 which gets sent to a 4digit extensio for the operator. I plan on porting some DID's from an acquired company but thier numbering range is 0700-07xx. How can I set this up so the system does not immediately dial the operator.
Thanks!
Overall Rating: 5 (1 ratings)
Chris Deren Fri, 08/08/2008 - 06:20
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Your best bet would be to either get another range or do internal translations, i.e. translate all extensions from 07XX to lets say 27XX, so internally people will dial 27XX (assuming 4 digit dialing).
Another approch is to introduce overlaps and hence interdigit delay when dialing 0, simply add TP such as 000X, so when one dials 0 CM will wait the inter-digit timeout before proceeding with the call to operator.
Chris
Knightvoice_2 Fri, 08/08/2008 - 06:37
Chris,
Thanks for the input. I am not worried about internal dialing of these extensions. I planned on setting up translation patterns to point to existing numbers in our dialing plan. So if 0400 comes in it will translate to 1500. Will the call go to the operator once CM sees the first 0 and will there be any voicemail issues on the 1500 extension?
Thnaks!
Chris Deren Fri, 08/08/2008 - 06:43
  • Hall of Fame,
Not if you setup Calling Search Spaces properly. Here is what you need to do:
1. create new parition i.e. _operator_PT
2. Assign this PT to the Operator translation pattern
3. Add this partition to the all calling search spaces that need to dial operator, make sure you do not include it in the CSS assigned to the GW.
4. Crate your 07XX translation pattern in a parition that is listed in the gateway CSS, but not phone CSS.
HTH, please rate all useful posts!
Chris
Knightvoice_2 Fri, 08/08/2008 - 06:56
The problem with that is the phones are currently in the same CSS as the gateway.
Chris Deren Fri, 08/08/2008 - 07:14
  • Hall of Fame,
Then creat a new CSS and apply it to the GW, you can just copy the one you have and dont include the the Operator partiotion in it.
Chris
  • Hall of Fame,
Chris
