CCM 4.1(3) SR7 CDR Query help needed
Aug 8th, 2008
I would like to run a CDR query on our call Manager to find anyone calling 0844 Numbers here in the UK.
I tried
select callingpartynumber from CallDetailRecord where finalcalledpartynumber='00844%'
but it seems the "%" is not a wildcard like in a ccm0300 Database query.
Any Hints?
Steff
testeven Fri, 08/08/2008 - 11:55
  • Cisco Employee,
Have you tried using the * wildcard instead?
Steffen.Baier Sun, 08/10/2008 - 07:49
I found the solution myself ;-)
I just use this:
select callingpartynumber,finalcalledpartynumber from CallDetailRecord where finalcalledpartynumber like '00844%'
In that case you get 2 rows, one with the extension that dialled the number and one with the called number.
You can also use:
select * from CallDetailRecord where finalcalledpartynumber like '00844%'
for all results or use the 1st example and just built your own by adding the headers of the * example and compare the 1st solution.
select callingpartynumber,finalcalledpartynumber,callingpartyloginuserid from CallDetailRecord where finalcalledpartynumber like '00844%'
Would give you 3 rows including the User ad of the User who dialed the Number using Extension Mobility.
Steffen
