Config Ethernet Management Port on Catl. 4506
Ayvalikslo2
How can I configure the Ethernet Management Port on SUP Engie IV Catl. 4506
What is config Interface name and the commmands to configure it as a IP interface.
I try use it for Outband Management
Thanks in advance for your help !
8 Replies 8
Edison Ortiz
interface fx/x
no switchport
ip address x.x.x.x y.y.y.y
__
HTH,
__
Edison.
Thanks for your support,
It is all about Port that directly connceted on the SUB module beside the Console Port
That port functions like any other switchport in the switch. It doesn't have any special feature.
If you want to assign an IP directly on the switchport, you need to make it a Layer3 switchport with the command no switchport and then input the appropriate IP address.
HTH,
__
Edison.
Please rate helpful posts
I seem to remember that this interface does not work when the Supervisor is running IOS. It is there purely for recovery and is only accessible when in ROMMON.
Andy
Andy,
Excellent catch. I was assuming he was talking about the uplink port.
According to:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/hw_doc/78_14496.htm
The Ethernet management port is used (in ROMMON mode only) to recover a switch software image that has been corrupted or destroyed due to a network catastrophe. This port is not active while the switch is operating normally.
__
You are indeed correct.
__
Edison.
I am new in Cisco Environment.
Have I a possibility to active the Ethernet management port?
As said already, I would like use it
as Outbandmanagement Interface and reach
an additional Interface posibility to config
and manage the switch like as console Port.
On Extreme Switches it is posible.
u cannot use this port for management purpose as said by earlier posters it is active in rommon mode only.
U can configure telnet to manage this switch remotely.
Mahmood
what is the name of Management Interface in rmmon mode.
