SSL URL rewrite Error Message
Aug 8th, 2008
Anybody ever come across the following error message:
%% Error sending config to fortune, service not activated
I receive this once I try to re-activate an SSL proxy-list on a CSS 11503 after configuring URL rewrite.
Thanks in advance,
Brendan
Brendan O'Flynn Fri, 08/08/2008 - 06:55
Update on this issue:
A reboot appears to have solved the problem, allowing me to activate the ssl-proxy-list after completing the urlrewrite configuration. Also testing has shown that the re-write works as expected.
Don't know why this should be the case but the testers had indicated that the CSS had stopped "working". After checking all the config (as I had made some changes to try and isolate my proxy-list issue) I decided to reboot (test environment) and this happily allowed testers to re-connect and fixed the SSL proxy-list problem.
I would still be interested to learn what it might be.
Brendan
