CM Discard Digit Instructions Not stripping correctly
Aug 8th, 2008
I have a route pattern that would like to strip down to 10 digit dialing but it doesn't remove the 1.
Test phone number is masked for privacy.
Details:
1. CallManager ver 4.1.3sr5d
2. No recent changes to route patterns. We did rearrange CSS and PTS to set ourselves up for toll-by-pass. We are a Central Call Processing install with 5 remote locations. We are planning on taking advantage of local toll call savings utilizing the voicegateway's located in all locations.
3. This will be a change to the dialplan and thus create the first route pattern as a test. The dialed number analyzer is currently what we are using to test with.
4. No errors just not correct output from Dialed number analyzer.
The issue is I am using the PreDot 11D->10D DDI.
The dialed number analyzer is telling me that my final Called party Transformation is Called Number = 1610392XXXX . The location is 10 digit dialing I do not need the 1.
Below is a report from the dialed number analyzer.
Call Flow
Results Summary
Calling Party Information
Calling Party = 8080
Partition = zeeland_pt
Device CSS = Zeeland
Line CSS = Zeeland
AAR Group Name =
AARCSS = Zeeland
Dialed Digits = 91610392XXXX
Match Result = RouteThisPattern
Matched Pattern Information
Pattern = 9.1610392XXXX
Partition = allentown-tollbypass-pt
Time Schedule =
Called Party Number = 1610392XXXX
Time Zone =
End Device = Allentown_Local
Call Classification = OffNet
InterDigit Timeout = NO
Allow Device Override = Disabled
Outside Dial Tone
PlayedAfter = 91
Route Pattern :Pattern= 9.1610392XXXX
Positional Match List = 1610392XXXX
DialPlan = North American Numbering Plan
Route Filter
Filter Name =
Filter Clause =
Require Forced Authorization Code = No
Authorization Level = 0
Require Client Matter Code = No
PreTransform Calling Party Number = 8080
PreTransform Called Party Number = 916103922219
Calling Party Transformations
External Phone Number Mask = NO
Calling Party Mask =
Prefix =
CallingLineId Presentation = Default
CallingName Presentation = Default
ConnectedParty Transformations
ConnectedLineId Presentation = Default
ConnectedName Presentation = Default
Called Party Transformations
Called Party Mask =
Discard Digits Instruction = PreDot 11D->10D
Prefix =
Marwan ALshawi Fri, 08/08/2008 - 07:13
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
try to make the pattren like
1.610392XXXX
instead of
1610392XXXX
because u have the line bellwo:
Prefix =
and good luck
TODD BERGMAN Fri, 08/08/2008 - 07:27
users dial 9 for outside then 1610392XXXX however the local calling area for 610 is 10 digit dialing so I must remove the 1. But here is a stupid question. If you dial a 1 and the number and the number you are dialing is a local call do you get a toll charge? If not I can probably just leave the 1 on there.
Brandon Buffin Fri, 08/08/2008 - 07:36
You should not get a toll charge in this scenario, but you might check with the carrier. You could also make your pattern 91.610392XXXX and use a PreDot DDI.
Hope this helps.
Brandon
TODD BERGMAN Fri, 08/08/2008 - 07:36
OK that is an idea that worked. Thank you.
Can you explain to me in a little more detail why the PreDot 11D->10D doesn't produce the number I was looking for?
Thanks a lot for your assistance.
Marwan ALshawi Fri, 08/08/2008 - 07:39
yes i think easier
Brandon Buffin Fri, 08/08/2008 - 07:51
Most DDIs apply only to route patterns that use the @ wildcard such as 9.@. PreDot is an exception.
Hope this helps.
Brandon
Ronald Spencer Wed, 02/04/2009 - 08:56
This is correct. The basic DDI's do the following:
NoDigits - Strips nothing. What you dial is what is presented. Note that digit string is prepended by the information in the Prefix digits section.
PreDot - removes everything before the . in your route pattern or translation pattern (ex: 912345.X would be X).
PreAt - strips everything before the @ sign, which represents any valid NANP number. (ex: 912345@ would change 9123456102234345 to 6102234345)
Trailing-# - strips the trailing terminating character (#). This is helpful with variable length dial plans (such as those for international calls).
Having said that, the rest of the DDIs will do the above, plus manipulate the @ sign.
You're example would have to setup as 9.@ with the DDI of PreDot 11D -> 10D to achieve what you want (using that DDI).
One note here is that @ is a POWERFUL wildcard. It opens up the dial plan and permits all valid NANP Numbers (Service, local, national, etc). To limit it, you should at a Route filter that would look for that area code. I believe it will filter out (reject) calls that match the filter. Having said that, you will probably want to have the 9.@ listed 2 times, the first with the filter and no DDI (Depending on the calling search space that it is in, you might set that pattern to block (to ensure that the user's aren't permitted to dial LD numbers). The second Route pattern would be the same (9.@) except you would remove the filter and add the PreDot 11D > 10D DDI.
Another Possibility is this:
route pattern 9.1610XXXXXXX with the PreDot DDI and a called party transform mask of XXXXXXXXXX. The Xs digits (place holders) are from right to left. So, if you have an 11 digit route pattern with a 10 X mask, it will drop the 1.
Please advise if this helps.
