Denied Attackers - Maximum?
Aug 8th, 2008
Does anyone know where I can find out the maximum number of denied attackers the ASA-SSM-10 running 6.1(1)E2 can handle? I see where you can set a timeout and total number for the denied hosts and denied network blocks but I haven't been able to find anything for the max number of denied attackers.
I'm am using this for a signature that is sometimes popular on our network and I'm concerned about impacting the performance of my IPS.
Thanks.
rhermes Fri, 08/08/2008 - 07:22
  • Gold, 750 points or more
The default number of blocked hosts is 250. You can see this with a "sh stat net" command. This can be configured from
conf t
service net
general
block-max-entries
marcabal Fri, 08/08/2008 - 09:54
  • Cisco Employee,
Blocks are different than Denies.
Blocks are for the modification of configuration on Switches, Routers, or Firewalls to get the other device to drop the traffic.
Denies are when the sensor itself drops the packets. The sensor must be operated in InLine mode for Denies to work.
To configure the max number of Denied Attackers you follow a similar procedure as rhermes posted, but it is controlled in the service event-action-rules rules0 configuration.
conf t
general
max-denied-attackers 10000
The default I believe is 10,000, but can be configured to be much higher or lower. Increasing this number could have a performance affect on your sensor, so be carefull when increasing this above 10,000.
