Tracing mac-address on 6509
Aug 8th, 2008
Hi all,
I am trying to trace a mac-address to find out what device it is and where is it connected. this is what I get
CENTSWCORE01# sh mac-address-table | include 001e.4a72.0d80
* 4 001e.4a72.0d80 dynamic Yes 0 Po305
* 3 001e.4a72.0d80 dynamic Yes 0 Po305
* 15 001e.4a72.0d80 dynamic Yes 5 Po305
* 12 001e.4a72.0d80 dynamic Yes 0 Po305
* 10 001e.4a72.0d80 dynamic Yes 5 Po305
* 11 001e.4a72.0d80 dynamic Yes 0 Po305
Does anyone knows what po305 is?
Jon Marshall Fri, 08/08/2008 - 06:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Po305 is an etherchannel connection. So in all likelihood your mac-address is on the device at the other end of the etherchannel.
"sh etherchannel summary" will show you which individual interfaces that form the etherchannel.
"sh cdp neighbor detail" will then show the devices on the other end of the interfaces.
You need to then log onto that device and run the mac-address-table command again.
Jon
emmanuel.shoroma Fri, 08/08/2008 - 07:06
Thanks.
From the device on the otherside of the turnnel, I get the foolowing
CENTSWCORE02#sh mac-address-table address 001e.4a72.0d80
Legend: * - primary entry
age - seconds since last seen
n/a - not available
vlan mac address type learn age ports
Active Supervisor:
* 4 001e.4a72.0d80 dynamic Yes 0 Po1
Another question. What is p01?
emmanuel.shoroma Fri, 08/08/2008 - 07:08
P01 seems to be pointing me back to the otherside.
CENTSWCORE02#sh cdp neighbors p01
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
CENTSWCORE01 Gig 2/48 176 R S I WS-C6506- Gig 2/48
CENTSWCORE01 Gig 5/2 171 R S I WS-C6506- Gig 5/2
froggy3132000 Fri, 08/08/2008 - 07:33
  • Bronze, 100 points or more
on the first CAT do
show interface po 305
on the other one do
show interface po 1
Its a cisco MAC so its mor than likely one of the interfaces.
abdel.ibrahim Wed, 10/01/2008 - 07:09
Po means port-channel.you might have some ether-channel bundles on the 6509, which this interface is bind to(305). Do show etherchannel port-channel to see all bindings.
