Can not make LD calls
Aug 8th, 2008
We have CCM 6.1.0 I have a user that used to be able to make Long Distance Calls but can not make them now. The Partition and Calling Search Space are ones that allow Long Distance Calls.
Is there a way to correct the problem?
Marwan ALshawi Fri, 08/08/2008 - 07:02
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
try to remove the phon and recreat it !!
also the route pattren for LD
jbarcena Fri, 08/08/2008 - 08:46
  • Red, 2250 points or more
Upload a CCM detailed trace from a call having the problem, include the calling party number, called party number and time of the call according the IP Phone and I will take a look.
//Jorge
