vpn connection with external modem
Aug 8th, 2008
Cisco 2651XM router
using a wic-adsl card I have been able to set up a successful vpn connection from a cisco vpn client machine to my 2651xm router but I can't get a connection if I use an external modem.
My lan at the vpn server end is on 172.16.1.xx and goes into the router on f0/0 which is set at 172.16.1.30.
Port f0/1 is on 192.168.1.100 and goes to an external modem set as default gateway
192.169.1.254. With this setup I can surf the internet on the lan machines at the server end.
Problem is I can't get a connection from a remote machine to vpn connect. It worked when I used the wic adsl connection but then I was only using
the f0/0 port which was connected to my lan. But now I'm including the f0/1 port to connect to an external modem the vpn client can't connect. The cisco vpn client tries to connect using tcp on port 10000 and I've set this up in the modem but not sure if I've done it correctly. I've tried forwarding the port to both 192.168.1.100 (f0/1) and 172.16.1.30 (f0/0) but neither will work. Attached is my running config. Thanks for any pointers.
router#show running-config
Building configuration...
Current configuration : 2757 bytes
version 12.4
hostname vpn
boot-start-marker
boot-end-marker
no logging buffered
no logging console
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxxx
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authentication login sdm_vpn_xauth_ml_2 local
aaa authorization network sdm_vpn_group_ml_1 local
aaa authorization network sdm_vpn_group_ml_2 local
aaa session-id common
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip name-server 192.168.1.254
ip name-server 192.168.1.255
ip ddns update method sdm_ddns1
DDNS both
username xxxxxxxxxxx secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group workgroup
key xxxxxxxxxx
pool SDM_POOL_2
crypto isakmp profile sdm-ike-profile-1
match identity group workgroup
client authentication list sdm_vpn_xauth_ml_2
isakmp authorization list sdm_vpn_group_ml_2
client configuration address respond
virtual-template 2
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA1
set isakmp-profile sdm-ike-profile-1
interface ATM0/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0/0
ip address 172.16.1.30 255.255.0.0
ip nat inside
ip virtual-reassembly
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
description $ETH-WAN$
ip dhcp client update dns server none
ip ddns update hostname vpn.vpn
ip ddns update sdm_ddns1
ip address dhcp client-id FastEthernet0/1
ip nat outside
duplex auto
speed auto
interface Virtual-Template2 type tunnel
ip unnumbered FastEthernet0/1
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
router rip
version 2
network 172.16.0.0
network 192.168.1.0
no auto-summary
ip local pool SDM_POOL_1 192.168.1.110 192.168.1.120
ip local pool SDM_POOL_2 172.16.1.21 172.16.1.29
ip http server
no ip http secure-server
ip nat inside source list 3 interface FastEthernet0/1 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 172.16.0.0 0.0.255.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 3 remark SDM_ACL Category=2
access-list 3 permit 172.16.0.0 0.0.255.255
control-plane
line con 0
line aux 0
line vty 0 4
password xxxxxxxx
end
Marwan ALshawi Fri, 08/08/2008 - 09:57
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
so now the public ip address shoud be on the modem
now the tunnel connection is comeing to the modem but because there is no maping (nating) to ur router that contain the IPsec VTI (virtual tuneel interface) the vpn wont work
u need static NAT/PAT to esp and ISAKMP to the router fa0/1 to get it work
also make sure nothing blocking thiese ports
i mean esp and isakmp
good luck
if helpful rate
tonyspcrepairs Fri, 08/08/2008 - 11:10
thanks for your response. I went into the modem and created a static route from the modem to the ip address of f0/1 but the connection still doesn't work. I don't know where the connection is failing, it's either at the modem or at the router. From the vpn client pc I can ping the public ip address of the server location and it replies fine. Is there any diagnostic I can run to find out where the connection is failing?
Marwan ALshawi Fri, 08/08/2008 - 18:00
now u can make vpn connection and u cannot communicate with local lan?
or u cant make the vpn connection at all?
also check if there is any filtering on the modem!
tonyspcrepairs Sat, 08/09/2008 - 02:24
I cannot make a vpn connection at all, I always get 'no response'. I'm almost certain the problem is the modem, it is not forwarding the connection to the router. I tried altering settings in the modem but still can't get a connection and I've also tried forwarding the TCP port to the router but no joy. I've written to the modem makers and I'm waiting for their reply, hopefully they will tell me what settings to alter in the modem.
Marwan ALshawi Sat, 08/09/2008 - 02:28
thats right
and good luck
if helpful rate
