Rate-limit
Aug 8th, 2008
From the statement below,the normal and max burst(2000 2000),are these parameters set up arbitrary or by calculation?Please advise
rate-limit input access-group 120 360000 2000 2000 conform-action
transmit exceed-action drop
Overall Rating: 5 (1 ratings)
rkhalil Fri, 08/08/2008 - 13:37
  • Bronze, 100 points or more
We calculate as follows...as specifications of Cisco.
Bits per second = MBits*1000000
Normal burst bytes = (Bits per second)/8*1,5
Maximum burst bytes = (Normal burst bytes)*2
Raul
(please rate helpful posts)
mukendi Mon, 08/11/2008 - 00:33
Hi Raul,
You are right,your answer can be verified by the statement below,keep it up!
rate-limit output 128000 24000 48000 conform-action transmit exceed-action drop
zamribesar Tue, 08/19/2008 - 07:28
So, if we have 155 Mbps, then it will be:
Bits per second = MBits*1000000 = 155000000
Normal burst bytes = (Bits per second)/8*1,5 = 29062500
Maximum burst bytes = (Normal burst bytes)*2 = 58125000
e.g:
interface gigabitEthernet 0/3
rate-limit input 155000000 29062500 58125000 conform-action transmit exceed-action drop
rate-limit output 155000000 29062500 58125000 conform-action transmit exceed-action drop
-zamri-
rkhalil Tue, 08/19/2008 - 07:45
Yes that's is ok.
