dtmf over SIP Trunk to VOIP Provider
Aug 8th, 2008
Anyone experienced issues with dtmf over sip trunks to VOIP Provider, all works good internally but does not work outbound dtmf or inbound on the auto attendant, i have tried all the dtmf relays in the dial-peer ooptions and nothing
mhering8650 Fri, 08/08/2008 - 08:50
What kind of Gateway? H323 or MGCP?
You have to set the dial peer to relay DTMF, and add something like dtmf-relay rtp-nte (depending on which SIP provider you have)
For example here is one of my SIP dial-peers
dial-peer voice 100 voip
translation-profile incoming DID_Incoming
translation-profile outgoing no-nine
preference 1
service session
destination-pattern .T
rtp payload-type cisco-codec-fax-ack 114
rtp payload-type cisco-codec-fax-ind 113
rtp payload-type nte 98
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
fax rate disable
fax protocol pass-through g711ulaw
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
