ssh for connecting
Aug 8th, 2008
  • Bronze, 100 points or more
when I try to insert the command:
transport intput/output ssh (I don't see the ssh option)
I only have those option:
DMZ_SW_01(config-line)#transport input ?
all All protocols
none No protocols
telnet TCP/IP Telnet protocol
Do I need to upgrade the IOS the switch is a C2950 ver IOS 12.1(22)EA10a
yanic
glen.grant Fri, 08/08/2008 - 08:14
  • Purple, 4500 points or more
You are probably not running the crypto version of code for the 2950. You must get crypto code and load it up on the switch.
jwheat Fri, 08/08/2008 - 09:26
You have to be running the crypto or SSH version of IOS code before you see the SSH option.
