ASA will not allow tftp to upload image.
Aug 8th, 2008
I get an error message:
%Error reading tftp:// (Unspecified Error)
Marwan ALshawi Fri, 08/08/2008 - 07:59
make sure u have connection to the server
and u have the put the right url
and also check the name of the image
phewes Fri, 08/08/2008 - 10:18
all of these have been checked. I can do the tftpdnld from rommon to get an image loaded, and the image works.
robertson.michael Fri, 08/08/2008 - 13:39
Hi Paul,
Do you see any logs on the TFTP server when you try to download the code?
I saw a similar issue where even though there were no connectivity or configuration issues, the TFTP server was refusing the connection for no apparent reason. The logs on the server showed the firewall trying to access the file, but the download failed. I ended up using a different server software on the same host (actually I switched to FTP), and the file downloaded just fine.
