Static IP
Aug 8th, 2008
I am planing to create a Wan using 5510 in the home office and 5505 on the branch offices. One question that I am need to have answered for planning purposed is whether you need a static IP on the branch office?
any help would be appreciated
Overall Rating: 4 (1 ratings)
Marwan ALshawi Fri, 08/08/2008 - 08:40
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
if u have only static on the head office should be fine if u wanna make vpn
if u make site to site vpn the branch office should start the session
or u can make it as easy vpn in this case the branch office asa will connect as a client to the head office
if u bring static for both in this case each one can start the session to the other one in stie to site vpn
good luck
please, if helpful rate
ibarrios Fri, 08/08/2008 - 08:54
Thank you for the answer that will make it easier to find providers for the dsl.
