Bulk import alternative extensions
Answered Question
Aug 8th, 2008
Hi guys, on unity bulk import I created a user with an alternative extension using the column header ALTERNATE_EXTENSION_1, this worked fine.
How can I bulk import a 2nd alternative extension, I tried using ALTERNATE_EXTENSION_2 but it failed. i assume the field header will be same if I either bulk import or bulk edit?
Also is there a similar field for the bulk import/edit of the sms notification
to (phone number) field?...cheers, Jag
Correct Answer by testeven about 8 years 9 months ago
Hi!
The tool appends the alternate extension into the list - it does not slide it into a specific "slot" for alternate extensions. So you can run the tool multiple times with different extensions for the same users and they are added to the alternate extension list.
You can also include this all in one file for example if you want to add 4 extensions to one user with a CSV file it will look something like:
ALIAS, ALTERNATE_EXTENSION_1
user1,1000
user1,1001
user1,1002
user1,1003
Hope this helps! :)
Overall Rating: 5 (1 ratings)
Correct Answer
testeven Fri, 08/08/2008 - 12:20
  • Cisco Employee,
Hi!
user1,1000
user1,1001
user1,1002
user1,1003
Hope this helps! :)
askq2forum Fri, 08/08/2008 - 13:39
Tere,
excellant, thanks for the info. Any news re bulk import for sms?
testeven Fri, 08/08/2008 - 14:02
  • Cisco Employee,
Hmmm sorry I haven't heard any news about that :(
