Redundant SUP2 shows status "other"
Answered Question
Aug 8th, 2008
  • Silver, 250 points or more
there is redundant SUP2 on catalyst 6509.SRM is also configured for MSFC.
In the output of show module the secondary SUP status is "other" . Can anyone explain what is wrong here ? and what can be done to rectify it ?
How can i check if the redundant SUP2 is in standby mode?
Thanks for your help in advance.
cat6509> (enable) show module
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP2-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
2 2 2 1000BaseX Supervisor WS-X6K-SUP2-2GE yes other
16 2 1 Multilayer Switch Feature WS-F6K-MSFC2 no standby
3 3 16 1000BaseX Ethernet WS-X6516-GBIC no ok
4 4 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
5 5 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
6 6 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
7 7 48 10/100/1000BaseT Ethernet WS-X6148-GE-TX no ok
cat6509> (enable) show system highavailability
Highavailability: enabled
Highavailability versioning: disabled
Highavailability Operational-status: ON
cat6509> (enable)
show redundancy
Designated Router: 1 Non-designated Router: 2
Redundancy Status: designated
Config Sync AdminStatus : enabled
Config Sync RuntimeStatus: enabled
Single Router Mode AdminStatus : enabled
Single Router Mode RuntimeStatus: enabled
Single Router Mode transition timer : 120 seconds
Correct Answer by garytayl about 8 years 8 months ago
If you are running 7.6(7) and 8.3(1) you would like to look at CSCee54278.
Also, the "other" status might also mean that sup has not properly booted and is stuck in ROMMON.
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 08/08/2008 - 13:40
  • Hall of Fame,
    Founding Member
Hello Saju,
everything is OK, the two supervisors cannot be active at the same time so the standby supervisor should be in a state different from OK
If I remember correctly the standby supervisor is shown as other
see
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a0080094713.shtml#st
and for redundancy
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/redund.html
use
show system highavailability on catos CLI
Hope to help
Giuseppe
Giuseppe Larosa Sat, 08/09/2008 - 01:05
  • Hall of Fame,
    Founding Member
Hello Saju,
I've given you a wrong info, I apologize for this.
I checked on my old job logs, actually the standby SUP should have state standby
c6509r4# (enable) sh module
2 2 2 1000BaseX Supervisor WS-X6K-SUP2-2GE yes standby
16 2 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
5 5 0 Switch Fabric Module WS-C6500-SFM no ok
So yours is a real issue. Follow other suggestions like trying to reset the standby module I'm afraid it doesn't support OIR (on-line insertion and removal).
So schedule a maintenance window power off the chassis reseat the module and then power on the chassis.
Hope to help
Giuseppe
Giuseppe Larosa Sat, 08/09/2008 - 02:37
  • Hall of Fame,
    Founding Member
Hello Saju,
can you access the MSFC on slot 16 with session 16 ?
If you can,from MSFC you can issue sh cdp n detail to check if the supervisor has loaded the CatOS.
Hope to help
Giuseppe
singhsaju Mon, 08/11/2008 - 05:46
Hi Giuseppe,
Thanks for the reply.
I can connect to session 16 but cannot authenticate after i am prompted for username and password?
Any idea why i cannot authenticate when i do session 16?
Saju
Correct Answer
garytayl Fri, 08/08/2008 - 13:50
