Syed Iftekhar Ahmed Fri, 08/08/2008 - 10:15
Why does it matter?
The back end servers never complains about :80
Is it only about port 80? or you want to translate different ports in requests to port 80 on the real server.
Syed
Syed Iftekhar Ahmed Fri, 08/08/2008 - 10:22
I got it.
For this you need to use SSL rewrite function.
This will ensure that the response from Real server is rewritten.
Configuration example.
If server is sending port 80 in the url and you want it get converted to 443.
action-list type modify http 80t0443
ssl url rewrite location ".*" sslport 443 clearport 80
policy-map type loadbalance http first-match syed-policy
class xyz
serverfarm sf1
action 80t0443
Details at
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/ssl/guide/terminat.html#wp1119436
Syed Iftekhar Ahmed
