HWIC-1T for 2801 router
Answered Question
Aug 8th, 2008
I'm trying to find which is the lower IOS version that I can use with this WIC, do you know where I can see ?.
Thank you.
Correct Answer by Richard Burts about 8 years 7 months ago
Luis
According to this link:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
it looks like the minimul IOS for this card is 12.3(14)T.
Rick
Correct Answer by 4rmorris about 8 years 7 months ago
Check out the Cisco Software Advisor. It has a search option for "Find Software Compatible with my Hardware":
http://tools.cisco.com/Support/Fusion/FusionHome.do
Good luck,
Ryan
Overall Rating: 4.3 (3 ratings)
lveraza Tue, 08/12/2008 - 07:10
Thank you,
Do you know the minimun IOS that support VWIC2-1MFT-T1/E1 ?.
Thank you.
