How to limit the User Input
Aug 8th, 2008
Hi guys,
I'm facing some problems with my script and if possible I would some help.
I have the following sequence in my script
First Prompt
Receive 4 Digits
Second Prompt
Choose Menu (1 or 2 or 3)
If I don't use interruptible prompt = no in the second prompt, when the user type more than 4 digits, and the fifth digit is 1 or 2 or 3,the script automatically send the user to the option.
is there any way to limit the user input ? I asked that cause I wanna create a lot of prompts and I don't want force the user listen all the prompts every time
My Best Regards,
Thanks in Advanced,
Andre Lomonaco
Chris Deren Fri, 08/08/2008 - 17:57
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Sure, on the first Digits collect under filter restrict it to 4 digits. Also, on the menu step under Input tab set the Flush Input Buffer to Yes.
HTH,
Chris
