Adding ASA5540 v7.0(7) to CSM 3.2 (pro)
Aug 8th, 2008
Cisco Security Manager 3.2 SP2
ASA5540 V7.0(7) single context, routed mode
Using the Device View to add an ASA, enter address, name and credentials and recieve error messge "unable to connect to the device. Device connectivity test between the device and CSM failed.."
I am succesfully able to ssh to the device from the same mgmt network.
With logging enabled I can see the ssh connection but do not see anything comming from CSM.
sample config below:
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http 192.168.0.0 255.255.255.0 mgmt
http 192.168.0.22 255.255.255.255 mgmt
http redirect mgmt 80
snmp-server host mgmt 192.168.0.22 community nnnnn
Many thanks
Steve
frekes Mon, 08/11/2008 - 05:47
Problem resolved. Appeared to be an issue with local IP connectivity, which is now resolved.
succesfully able to add ASA as device into CSM.
Steve
