08-08-2008 06:22 PM - edited 03-15-2019 12:30 PM
I have a CUCM 6.0 and 2 ISR2811 acting as H.323 gateways in 2 different branch offices. I have configured a Route Group that with this 2 GWs. The goal is to redirect calls to a second gateway if all the ports in the first one are busy. It's notworking. POTS dial peers are configured in each GW for each dial pattern. I also tried DPs with preference like the folowing ones
dial-peer voice 7 pots
!First dial peer, if busy redirects call to dp 71
preference 1
destination-pattern 79........
port 0/1/1
prefix 9
dial-peer voice 71 voip
!Second dial peer, redirects call to second GW.
preference 2
redirect ip2ip
session target ipv4:10.0.0.1
codec g711alaw
it's not working. Can someone find the reason?
Solved! Go to Solution.
08-11-2008 04:34 PM
One option as already discussed is to use a dial-peer on the 1st router that points to the second in the event of failover.
There are also 2 CUCM service parameters that can effect how CUCM will hunt/failover with H323 route groups.
"Stop Routing on Out of Bandwidth Flag"
Default: True
"Stop Routing on User Busy Flag"
Default: True
Setting these parameters to false will allow failover to a second route group member if the 1st cannot complete the call.
08-08-2008 07:16 PM
ok try this idea
first in global config mode do the following command
voice service voip
this will let the gateway to route between h323 dialpeers so ur gatw1 will route the call to gateway two ip address[10.0.0.1]
for addition features
u can add the following command to restrect for example dial-peer 7 to a spefified number of calls
max-conn [max number of calls]
but i sugesst u to add the allow h323 to h323 option as mention above and try it should be fine
by the way i am not sure about the effict of ur command [redirect ip2ip ] in dial-peer 71!!
NOTE: the default time for an h323 dial peer to time out and go to the second one is 15 second so the caller should wait 15 second to be redirected
if u want to decrease this time for example make it three seconds follow the following[ i tried it with voip dial peers but i didnt with pots just for ur information i put it]
voice class h323 1
h225 timeout tcp establish 3
voice-class h323 1
good luck
please, if helpful rate
08-08-2008 07:38 PM
The reason your Route Group is not working is because they are H.323 gateways and not MGCP gateways. With MGCP, CUCM actually interfaces with the ISDN D channel directly, so it knows when the PRI/Pots line is full/Down. Now if that gateway becomes unreachable then it will switch over to the other device in your route group.
Now on to how to fix your problem.
1. Is there anything on 10.0.0.1's inbound dial-peer that would stop this Gateway's outbound dial-peer from being matched?
2. Are you seeing the outbound dial-peer being matched when the primary dial-peer is full/down?
08-09-2008 01:48 AM
Andrew the way JuanCarlos try to configure his gateways with is right and configurable 100%
only what he needs just to add the command i have mentioned above
now he even if he wants, he can remove the second gateway from the route group because the call will be forwarded from gateway one to two as a h323 VOIP call in case of the GW1 pstn line conjested or the line is down
thank you guys
and good luck for JuanCarlos
08-11-2008 08:34 AM
Marwan and Andrew, thanks a lot for your quick and accurate response.
I tried what you suggested and it works but there's no ringback and the call disconnects after 5 seconds. I'm checking the reason. If you have any suggestion please let me know. Thanks again!
08-11-2008 04:18 PM
i am happy the mainidea worked
about get disconnected
try to make the codec on the voip dialpeers as g711 !!
please rate the helpful post
and good luck
08-11-2008 04:34 PM
Default: True
Default: True
08-14-2008 08:14 AM
Thanks Marwan, Andrew and Christopher for your help. It's working fine right now. The main issue was the flags mentioned by Christopher. As soon as I changed it started working. Thanks again!
