Link aggregation on ASA
dhananjoy chowdhury Fri, 08/08/2008 - 20:47
On the ASA, you can terminate both the Internet links but ASA will use only one link.
Because ASA can handle only one default route.
Now what you can do is, you can create 2 contexts and use one Internet link in each context and distribute the internet load on the two contexts as per your requirements.
But again , you need to consider the fact that , if you configure the ASA box in context mode, then features like VPN, Dynamic protocols etc are not supported.
