Marwan ALshawi Sat, 08/09/2008 - 02:41
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
host ip represent the vpn termination device in ur case thr router
while the client ip represent the vpn user ip address
because, the vpn user after connecting to through the vpn to the router will be given an ip address from pool u gonna make it
please, if helpful rate
Roshan8484 Sun, 08/10/2008 - 00:50
hello,
thanks this was very helpful and I will definately rate you well.
So my current router ip is set at 192.168.1.1 is that what my host Ip should be?
If the above is my host IP how does my VPN Client know to connect to my router and not someone elses if 192.168.1.1 is a common router IP?
Thanks again
Marwan ALshawi Sun, 08/10/2008 - 02:26
the 192.168.1.1 is a private ip u cannot use it over the internet u need a publice static ip address to use it over the internet which u can get it from ur ISP
the follow link will be usefull by the way in following example the 10.1.1.1 used as the vpn host ip address only for the example perpus
http://www.cisco.com/en/US/products/sw/secursw/ps5318/products_configuration_example09186a00806ad10e.shtml
hop this helpful
