Ipsec site to site
Answered Question
Aug 9th, 2008
Am using Ipsec between two Routers (site to site) in lab environment for testing.
. The Router A local LNA is not pinging to remote Router B and crypto section is showing down. Please provide the solution for making up this scenario.
The detailed configuration is as follows
Router B
Building configuration...
Current configuration : 957 bytes
version 12.4
hostname AIRTEL-DELHI
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key cisco123 address 192.168.10.2
crypto ipsec transform-set manju ah-sha-hmac esp-des
crypto map 1 10 ipsec-isakmp
set peer 192.168.10.2
set transform-set manju
match address 110
interface FastEthernet0
ip address 10.97.37.212 255.255.255.0
speed auto
crypto map 1
interface Serial0
description AIRTEL-BANG [192.168.10.2]
ip address 192.168.10.1 255.255.255.252
no ip http server
no ip http secure-server
access-list 110 permit ip host 192.168.10.1 host 192.168.10.2
control-plane
line con 0
line aux 0
line vty 0 3
login
line vty 4
password cisco
login
end
Router A
Current configuration : 955 bytes
version 12.4
hostname AIRTEL-BANG
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
crypto isakmp key cisco123 address 192.168.10.1
set peer 192.168.10.1
match address 110
ip address 172.26.8.10 255.255.255.0
speed auto
crypto map 1
interface Serial0
description AIRTEL-DELHI[192.168.10.1]
ip address 192.168.10.2 255.255.255.252
interface Serial1
no ip address
shutdown
no ip http server
access-list 110 permit ip host 192.168.10.2 host 192.168.10.1
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Correct Answer by thiru.vel10 about 8 years 8 months ago
Try this command sh ip crypto isakmp sa
Then check the status
Correct Answer by rsgamage1 about 8 years 8 months ago
I suppose your interesting traffic is between 10.97.37.0/24 and 172.26.8.0/24 networks, and your peers are 192.168.10.1 and 192.168.10.2 respectively.
Isn't it something like the following that you are looking for?
Try pinging between these networks and see whether it is through the tunnel(debug crypto <> options)
Router B
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
hash md5
match address 110
speed auto
interface Serial0
crypto map 1
no ip http server
access-list 110 permit ip 10.97.37.212 0.0.0.255 172.26.8.10 0.0.0.255
ip route 172.26.8.0 255.255.255.0 192.168.10.2
control-plane
line con 0
line aux 0
line vty 0 3
login
line vty 4
password cisco
login
end
Router A
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
match address 110
speed auto
interface Serial0
crypto map 1
interface Serial1
no ip address
shutdown
no ip http server
access-list 110 permit ip 172.26.8.10 0.0.0.255 10.97.37.212 0.0.0.255
ip route 10.97.37.0 255.255.255.0 192.168.10.1
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Overall Rating: 4.5 (3 ratings)
Edison Ortiz Sat, 08/09/2008 - 04:44
  • Hall of Fame,
    Founding Member
The 'interesting' traffic in your ACL should be your LAN subnets, not the serial links.
For instance:
Router B:
access-list 110 permit ip 10.97.37.0 0.0.0.255 172.26.8.0 0.0.0.255
Router A:
access-list 110 permit ip 172.26.8.0 0.0.0.255 10.97.37.0 0.0.0.255
HTH,
__
Edison.
Please rate helpful posts
Correct Answer
rsgamage1 Sat, 08/09/2008 - 04:47
  • Bronze, 100 points or more
Router B
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
hash md5
match address 110
speed auto
interface Serial0
crypto map 1
no ip http server
control-plane
line con 0
line aux 0
line vty 0 3
login
line vty 4
password cisco
login
end
Router A
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
match address 110
speed auto
interface Serial0
crypto map 1
interface Serial1
no ip address
shutdown
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
ntmanjunath Sat, 08/09/2008 - 05:47
After doing above said configuration the output is as follows.
Router#sh crypto session
Interface: Serial0
Session status: UP-IDLE
Peer: 192.168.10.1 port 500
IKE SA: local 192.168.10.2/500 remote 192.168.10.1/500 Active
IPSEC FLOW: permit ip 172.26.8.0/255.255.255.0 10.97.37.0/255.255.255.0
Active SAs: 0, origin: crypto map
How to check the secured tunnel between to peers.
rsgamage1 Sat, 08/09/2008 - 08:06
For you've setup a testbed, it would be interesting to study the output of debug crypto in order to have a better understanding.
HTH.
thiru.vel10 Sat, 08/09/2008 - 04:54
Hi there is there is no routing between the LAN Subnets so. Please try to add this
Router A
IP route 10.97.37.0 255.255.255.0 192.168.10.1
Router B
IP route 172.26.8.0 255.255.255.0 192.168.10.2
rsgamage1 Mon, 08/11/2008 - 00:24
Did you manage to perform required tests successfully?
ntmanjunath Mon, 08/11/2008 - 00:40
Yes I did .After successful configuration the site was working and session was up. Unexpectedly I used clear crypto isakmp common and session never came up and still its showing down only
rsgamage1 Mon, 08/11/2008 - 00:49
Even when you try to put some interesting traffic (e.g. by pinging from one internal network to the other) ?
Have you tried debug crypto {isakmp/ipsec/verbose} to see what they say?
ntmanjunath Mon, 08/11/2008 - 01:25
I tried for pinging from local Ethernet to remote and still it's showing the same status.
Do u know how to enable display for debug.
When I try the command debug crypto isakmp nothing is display.
Correct Answer
thiru.vel10 Mon, 08/11/2008 - 04:21
