cisco WS-C6509
Aug 9th, 2008
My switch is having some problem.I am seeing all these.
Switch#show mod
Mod Ports Card Type Model Serial No.
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE SAL0702BJLK
2 0 Supervisor-Other Unknown Unknown
Can i reset the second sup remotely using this command.
hw-module module 2 reset or
ask someone to pull the card physically(Hot swappable)
Does it have any impact on the switch.
Giuseppe Larosa Sat, 08/09/2008 - 11:51
Hello Arun,
you can try to reload the module with
if this is not enough have someone to reseat the card but verify it is hot-swappable I always powered off the switch when dealing with supervisors
It looks like to be hot-swappable
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Module_Installation/Mod_Install_Note/78_15767.html#wp51279
Hope to help
Giuseppe
Ryan Carretta Sun, 08/10/2008 - 22:50
All modules in a 6500 chassis are hot-swappable, including the supervisors. This is called online insertion and removal. There is a very small but real risk that there could be a switching bus stall when any module is inserted or removed and the system is in centralized forwarding mode.
