BGP AS
Aug 10th, 2008
Hello All:
I there any current IOS that will support 4-byte AS.
If there is could some one tell me the version ?
Is there any document on this if something is going on to support this by cisco.
Thanks in advance
Overall Rating: 3 (2 ratings)
vishwancc Sun, 08/10/2008 - 08:11
Hi Guru,
Thanks for the quick response .
But could you tell me where does in IOS-XR release it says to support 4 byte AS.
Do you have any link that cisco is still working on it.
Thanks again.
guruprasadr Sun, 08/10/2008 - 08:29
  • Gold, 750 points or more
HI Vishwa,
I don't have any LINK that says about Cisco's current status or the future prospect.
Let's wait for some Cisco Employees / Experts to add more information.
Best Regards,
Guru Prasad R
Edison Ortiz Sun, 08/10/2008 - 10:16
  • Hall of Fame,
    Founding Member
No.
We usually don't publish documents for future feature releases on hardware and software. With that said, there will be support for this feature - I can't tell you what hardware/software will support if - as of yet.
__
Edison.
guruprasadr Sun, 08/10/2008 - 22:46
HI Edison,
Thanks for your intervention on this POST.
Best Regards,
Guru Prasad R
vishwancc Mon, 08/11/2008 - 04:02
Hi Edison,
Thanks for your attention and response.
When cisco will release the software please let me know.
Thanks in Advance.
Vishwa
