Resetting IP 7960 phone
mhering8650 Mon, 08/11/2008 - 14:07
Unplug the power cable from the phone, and then plug in the cable again.
The phone begins its power up cycle.
Immediately press and hold # while the Headset, Mute, and Speaker buttons flash in sequence.
Release # after the Speaker button is no longer lit.
Once the 3 buttons at the bottom flash in sequence Press 123456789*0#
If you do it right it will ask if You want to keep the network cfg...
(*If you don't do it right the phone will just reset normally*)
BTW, there is no such thing as a MGCP Phone, MGCP is for Gateways, I think you are thinking of SCCP
I tried that but each time I hold the # key while the phone powers up, after the speaker button is no longer lit- nothing flashes. The phone just boots up normally. I have tried this over a dozen times to no avail. Could this reset functionality not be available for the firmware I have?
The Status screen shows:
Application Load ID: P0M3-04-4-00
Boot Load ID: PC030300
TIA,
CJ
