Aug 11th, 2008
What would be the problem the crypto session shows down.
But I can ping peer to peer.
AIRTEL-DELHI#sh crypto se
Crypto session current status
Interface: Serial0
Session status: DOWN
Peer: port 500
IPSEC FLOW: permit ip
Active SAs: 0, origin: crypto map
Richard Burts Mon, 08/11/2008 - 03:24
When you ping is the source address in (the source addresses apparently selected in the access list that is part of the crypto map)?
Other than possible issues is the addressing there are several other things that might keep the session from coming active. These might include:
- possible mismatch of preshared keys.
- possible mismatch of ISAKMP parameters.
- possible mismatch of IPSec parameters.
- possible filtering of the ISAKMP or IPSec packets.
It might help us to find your problem if you would post the config.
