Parallel Hunt Group SCCP
Answered Question
Aug 11th, 2008
I've got a new UC520 here, When I type voice hunt-group 1 parallel, list, then enter 2 DN numbers, it whinges about number xx not being a DN number.
It is a DN number as i can see it and it works... Is this trying to use the SIP parallel hunt group setting and not the SCCP hunt group?
Correct Answer by Jaime Valencia about 8 years 11 months ago
you need CME 4.3 to use parallel hunting with SCCP, UC520 has CME 4.2 which only supports SIP parallel hunting
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 08/11/2008 - 08:41
  • Cisco Employee,
  • Hall of Fame,
    2011
java
