Boot path on switch stack
Answered Question
Aug 11th, 2008
I have uploaded a new IOS on a 3750 stack. Stack consists of two switches, a master and a member.
I have configured the master's boot path with a newaly extracted IOS. But the thing is that the member switch is still configured with an old path and I can not change it. Will master switch upgrade the stack member after reload? Is there any way to manually configure member switch with a new boot path?
BOOT path-list : flash2:/c3750-advipservicesk9-tar.122-44.SE2/c3750-advips
rvicesk9-tar.122-44.SE2.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
Switch 2
BOOT path-list : flash:c3750-ipbase-mz.122-25.SEE3/c3750-ipbase-mz.122-25.
EE3.bin
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : no
Correct Answer by dinesh.das about 8 years 11 months ago
I think auto upgrade is disable on switch 2, refer following link for IOS upgradation of stack.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml
Overall Rating: 4 (1 ratings)
