08-11-2008 03:41 AM - edited 03-13-2019 05:33 PM
Want to migrate 4.2(3) CM configuration to 6.0.1.1000-37 CUCM.
I've downloaded 'DataMigrationAssistant-6-0-1a.exe' file to make a .tar archive.
Should I upgrade my 6.0.1 CUCM to 6.0.1(a) version to allow the import process to be successfull ?
Or it'll be possible to perform all the configuration based on current 6.0.1 version ?
Solved! Go to Solution.
08-11-2008 05:41 AM
Good morning Tobvian,
DMA version 6.0(1a) should work for upgrading from CUCM 4.2(3) to 6.0.1.
You might, however, run into CSCsl26081 (Upgrade from CUCM 4.2(3)SR3 to CUCM 6.0(1) fails), so hopefully as you did your potential problem analysis you planned to implement the workaround described in the bug.
Hope this helps.
Michael.
08-15-2008 07:21 AM
Hi Tobvian,
Thanks for posting the DMA logs. These logs show the following error just before the rollback of the installation:
10:55:15: DMAInstall.cpp: fnInstallDMA: <-- fnInstallDMA
Action 10:55:15: IDSInst4.
Info 1720.There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor. Custom action IDSInst4 script error -2146827850, Microsoft VBScript runtime error: Object doesn't support this property or method: 'CurrentDirectory' Line 4, Column 1,
Action 10:55:15: IDSInstall. IDSSetup
These errors match the bug documented in CSCsi69720 - DMA Install to Check Window Script Engine Version.
The workaround is to download and install Windows Script 5.6 for Windows from the Microsoft web site and then reinstall DMA.
Michael.
08-11-2008 05:41 AM
Hope this helps.
Michael.
08-13-2008 12:30 AM
08-15-2008 07:21 AM
Hi Tobvian,
Michael.
08-17-2008 11:51 PM
MICHAEL, thank you a lot. It works !
