Bandwidth Quiestion
Answered Question
Aug 11th, 2008
Hai,
Sorry if this is a basic question, I used to get confused regarding the BW issue. For Eg: if ISP link having BW 2 Mbps how would the download and upload happens. Can I download 2 mbps data and upload 2 mbps of data at a time. Tried to find out some tech notes but couldn't any one useful
Also what does 1:1, 1:2 etc means (if the BW is 2 Mbps) from Service provider end will they do any config in this case at ISP Router side..
Thanks in advance
Lijesh.N.c
Correct Answer by royalblues about 8 years 10 months ago
When you say 2Mb 1:1, it means you have been dedicated full 2Mb (upload/dwonload) from the ISP
If it is 2Mb 1:4, at any given point of time you are assured of only 512k out of the 2Mb. The rest is shared but you can burst upto 2Mb when there is available bandwidth
Narayan
Overall Rating: 5 (1 ratings)
gojericho0 Mon, 08/11/2008 - 08:22
  • Bronze, 100 points or more
What type of connection are you using to connect to your ISP?
CSCO10758684 Mon, 08/11/2008 - 20:43
Hai,
Thanks for the reply ..i am using Leased Line (2 Mbps 1:1)
Lijesh
Correct Answer
royalblues Mon, 08/11/2008 - 22:16
  • Green, 3000 points or more
Narayan
CSCO10758684 Mon, 08/11/2008 - 22:43
Hai Narayanan,
Thanks for the reply.Now the dout is cleared.One more qstn if customer asked for 2 Mb 1:4 ..from isp side wud there be any config change for this perticuler cusotmer (mean any rate limit ..etc )
Lijesh.N.C
royalblues Mon, 08/11/2008 - 22:51
Well i do not knwo the exact configuration that is done at the ISP side but they will configure it in a way that all times we have dedicated allocation of 512kbps to the internet.
It would similar to how we do QoS by assigning certain minimum bandwidth for one customer and sharing the rest with other customers
Narayan
CSCO10758684 Mon, 08/11/2008 - 23:04
Hai,
Thanks narayan ..i am tru ...now.... thanks a lot once again ...
Lijesh.N.C
