Warning message
Uplodaing Running Config Question
Aug 11th, 2008
Having some challenges uploading Running-config to router.
Router: 871w with VPN
I have tried uploading via console and SDM. The file was saved with SDM.
What do I need to leave out to make the process work (using SDM and/or console).
scotian_gold2900 Mon, 08/11/2008 - 08:22
Thanks for the reply.
I will review the link.
How I was trying to upload was:
Method A) Using SDM, under Additional Tasks, there's a configuration section where you can upload or merge running config. Since this did not work - I assumed it had errors.
Method B) Logged into Console using Console cable and Hyper Terminal. I when into config t and selected File > Send Text file.
It looked as if I was getting error messages with secret password and crypto items.... might be anything that was encrypted? I thought this method would work.
