Controlling ISDN Caller ID in SRST mode
Aug 11th, 2008
Hey Everyone
I'm sure the answer is right in front of me and I just can't see it :)
I have a H323 gateway connected to my CCM 5.1 cluster, with it's own PRI
Everything is fine normally, but if the wan link goes down and the phones go into fallback mode they cannot make calls.
From the 931 Debugs, I see the calls hitting the PRI with the correct digits, but the caller ID that is being transmitted is the 5 digit extension instead of the full DID which is causing the phone company to reject the call.
How can I get the Gateway to send correct caller ID when in SRST mode
Thanks in advance
Overall Rating: 5 (1 ratings)
Chris Deren Mon, 08/11/2008 - 06:23
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You can create a translation rule to append digits, i.e.
Assume that your internal extensions begin with 7 and are followed by 4 digits, and you are in area code 312 exchange 595
voice translation-rule 2
rule 1 /7\(....\)/ /312595\1/
voice translation-profile SRST-CALLERID
translate calling 2
call-manager-fallback
translation-profile outgoing SRST-CALLERID
Chris
mhering8650 Mon, 08/11/2008 - 06:30
Thanks for the quick reply :) but I already tried that and it's not appending the numbers..
Here is what I have..(Mabye I dumb fingered something ;) )
rule 1 /^708\(..$\)/ /64623755\1/
voice translation-profile srst
translate calling 2
Call-manager-fallback
translation-profile outgoing srst
Here is my SRST config...
NY545VGW01#sh run | be call-manager
secondary-dialtone 9
max-conferences 3 gain -6
transfer-system full-consult
ip source-address 1.2.3.4 port 2000
max-ephones 42
max-dn 96
system message primary **MPLS Down, Fallback enabled**
dialplan-pattern 1 64623755.. extension-length 2
default-destination 70877
voicemail 912123722121
call-forward noan 912123722000 timeout 15
Chris Deren Mon, 08/11/2008 - 06:44
  • Hall of Fame,
How about if you apply it to an outbound dial-peer vs. callmanager-fallback?
Chris
mhering8650 Mon, 08/11/2008 - 06:46
Yeah I was thinknig that....but then I' have to setup Corlists etc that would only apply in SRST mode (Need to control caller ID for other things in normal mode)
Let me give that a shot.... Was hoping to avoid that but oh well :)
Chris Deren Tue, 08/19/2008 - 15:46
  • Hall of Fame,
Caller name is controlled by the telco providers, they will override whatever you outpulse. For inboud calls if you see caller name (debug isdn q931) Cisco can deliver it.
Chris
