CME 4.0.2
Aug 11th, 2008
I have a 2801 with the cme ver 4.0.2.
I want to connect 7945 and 7937 conference station. I think the ios that supports the 7937 is ver 4.3.
I tried to install it but there was a problem in the pstn lines after one minute every telephone call was disconnected.
Could you please advice me what to do.
Overall Rating: 3 (1 ratings)
jbarcena Mon, 08/11/2008 - 07:34
Well you can only upload the phone loads to the flash and then to the tftp.
michalis1234 Mon, 08/11/2008 - 08:32
Do you think that the conference station 7937g will work fine?
In he cisco website it is recommended that no version of ios below of 4.3 supports this model?
Have you tried it?
Thank you very much.
michalis1234 Tue, 08/12/2008 - 00:43
I tried to load the firmware of the 7937G station to the ccme ver 4.0.2 (2801)
but there was no such type of phone when i typed the command load:
CCME(config)#telephony-service
CCME(config-telephony)#load ?
12SP Select the firmware load file for 12SP+ and 30VIP phones
7902 Select the firmware load file for 7902
7905 Select the firmware load file for 7905
7906 Select the firmware load file for 7906
7910 Select the firmware load file for Telecaster 7910 phones
7911 Select the firmware load file for 7911
7912 Select the firmware load file for 7912
7914 Select the firmware load file for sidecar 7914
7920 Select the firmware load file for 7920
7931 Select the firmware load file for 7931
7935 Select the firmware load file for 7935 Conference Station
7936 Select the firmware load file for 7936
7941 Select the firmware load file for 7941
7941GE Select the firmware load file for 7941GE
7960-7940 Select the firmware load file for Telecaster 7960 & 7940 phones
7961 Select the firmware load file for 7961
7961GE Select the firmware load file for 7961GE
7970 Select the firmware load file for 7970
7971 Select the firmware load file for 7971
ATA Select the firmware load file for ATA
Is there any other way to load the new phones?
Also the file i downloaded is an .exe instead of .bin
Is it the correct extension ? I tried to extracted but couldn't.
michalis1234 Wed, 08/13/2008 - 04:11
I upgraded the ios of the 2801 to c2801-ipvoicek9-mz.124-15.XZ.bin which has cme ver 4.3 But unfortunatelly, the conference station 7937G does not register.
I have also downloaded on the flash
the firmware of the 7937g: apps37sccp.1-2-1-0.bin.
I want to load from the telephony-service the firmware but i cannot there is no option.
load ....(there is no 7937 type).
Is it not supported as well?
the tftp command is there as well.
tftp-server flash:apps37sccp.1-2-1-0.bin
I tried ios c2801-ipvoicek9-mz.124-15.XZ1, ver cme 7.0 but I had a problem with PSTN lines after some secs when i place or receive a call it disconnects.
Is there any other command I should input?
