CWLMS 3.0 on Windows 2003
Answered Question
Aug 11th, 2008
Some proccess not start automatically.
Two of this are: ANI Server and JRM
Here attach status process.
Please, I need to resolve this issue shortly time
Best regards!
Thanks a lot!!
Correct Answer by Joe Clarke about 8 years 10 months ago
This problem is different from the Gatekeeper issue. Please start a new thread to troubleshoot syslog.
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 08/11/2008 - 08:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the jrm.log, ani.log, and ANIServer.log.
Joe Clarke Tue, 08/12/2008 - 10:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Shutdown Daemon Manager, then capture the output of netstat -a -n -o -b, and post it.
Joe Clarke Wed, 08/13/2008 - 08:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post screenshots showing your Service startup parameters.
expe_0626 Thu, 08/14/2008 - 07:07
Hi JClarke!
here attach a document with print screen of computer management - services and proccess managemet of CWorks.
thanks!!
Joe Clarke Thu, 08/14/2008 - 07:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This looks good, but I don't understand why your netstat output still lists Apache, Tomcat, and dmgtd as running. How did you shutdown Daemon Manager when you capture the netstat output?
expe_0626 Thu, 08/14/2008 - 10:43
Hi Jclarke!
I did a shut of the Daemon and then the same with the netsat. If you want I can do it again. After I restarted it.
However, when I restart the processes shutdown in the CW, the process ANI, syslog, and jrm, remained in the "Administrador has shutdown the Server"
When I want to enter some errors appeared (see the attached file). I think they can't connect to some base..
best regards!
thaks!!
Joe Clarke Thu, 08/14/2008 - 10:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post your NMSROOT/lib/vbroker/gatekeeper.cfg.
Joe Clarke Thu, 08/14/2008 - 11:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Found the problem. You have something called FrameworkService bound to tcp/9091. This port must be free for the Gatekeeper. If you shutdown this service, then restart Daemon Manager, you should be set.
expe_0626 Fri, 08/15/2008 - 12:23
Hi Jclarke!
Thanks!! now the services are running
But, have problems with Syslog,
When a try to subscribe, I get the error:
SLCA0126: Could not subscribe to the Collector.
1.Check whether the collector is running.
2.Make sure that SSL certificates are imported/exported correctly and process restarted.
3.Check whether the Certificates exported/imported are valid and have not expired.
4.Check whether SyslogAnalyzer process is running.
The SyslogAnalyzer its running, I have to start up manually.
Best regards!
thanks again
Correct Answer
Joe Clarke Fri, 08/15/2008 - 13:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
expe_0626 Tue, 08/19/2008 - 04:22
Jclarke! ahh ok I undersnatd. Thanks a lot! best regards,
