CCM 4: CDR Login Issue
Answered Question
Aug 11th, 2008
Hi Friends,
On CCM 4.2(3) publisher i install CDR Analaysis and Report tool in order to generate report for international calls. Problem is i am unable to login first time using user/pass admin/admin. I also tried other passwords but i recieve the same error message "LDAP Access Error. Contact to Administrator". I did all the basic steps to troubleshoot but couldn't solve it. One thing i will mention that after enabling CDR now when i make call, it records in sql database table with all information so i thing only problem with cdr web interface. Another thing before CDR Tool installation process i recieved an alert "authenticode on found. Do you want to continue".
Please help me out in this regard.
Hoping for your prompt relpy
Best Regards
Rameez
Correct Answer by espereir about 8 years 10 months ago
Hello Rameez,
If CCM is integrated with AD, go to the Cisco OU and delete the "CiscoAdminRepToolAdminGroupUsers" group, then on CCM, restart IIS by issuing the "iisreset" command and then go to CAR again and login with the admin/admin account. After doing that, assign Administrative rights to an user and log off CAR. At this point the "CiscoAdminRepToolAdminGroupUsers." group should have been regenerated and the accounts that you have added as CAR administrators must be listed there. At this point, you just need to login with the new CAR Administrator account and share the results with us ;).
In case that you have DC instead of AD;
follow the instructions below:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801115eb.shtml
Hope this helps!
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 08/11/2008 - 10:26
  • Cisco Employee,
  • Hall of Fame,
    2011
integrated with DCD or AD??
you can look the reptooladmingroup in the directory and find out who is a member to log in
java
if this helps, please rate
Correct Answer
espereir Tue, 08/12/2008 - 00:12
  • Silver, 250 points or more
Hello Rameez,
Hope this helps!
espereir Tue, 08/12/2008 - 07:43
Good to know and you are welcome!
