cannot upgrade 2106
Answered Question
Aug 11th, 2008
i have a 2106 with version, installed. when i attempt to upgrade the unit with the current os i recieve;
file transfer failed!
I have tried several tftp programs and i recieve the same results, please help.
Correct Answer by Scott Fella about 8 years 2 months ago
No problem.
Overall Rating: 5 (1 ratings)
Scott Fella Mon, 08/11/2008 - 10:21
I like to use 3CDeamon for TFTP.... also make sure you can ping the management interface of the WLC from the tftp server. Disable any firewalls on the tftp server and look at the logs on the tftp server to see any activity. What code are you trying to upgrade the 2106 to?
davidummel_2 Mon, 08/11/2008 - 10:23
thank you i will give it a try.
this is the code i am tring to update to;
davidummel_2 Mon, 08/11/2008 - 11:02
what i recieve with the selected file using the program sugested is;
Aug 11, 2008 12:04:10 Session 9, Peer TFTP Server session started
Aug 11, 2008 12:04:10 Session 9, Peer Client requests GET of file C:\1\c:\1\AIR-WLC2100-K9-4-1-185-0-ER.aes.
Aug 11, 2008 12:04:10 Session 9, Peer Could not open requested file for reading
Scott Fella Mon, 08/11/2008 - 11:36
Looks like either you are pointing to the wrong directory or the file name you entered on the wlc is wrong. Create a folder on your desktop and point the tftp to that and see if that works.
davidummel_2 Tue, 08/12/2008 - 06:00
Thank you,
i had to sleep on it to figure out what i was doing wrong.
in the contoler gui i was selecting the tftp directory, i was doing the same within the tftp program. it was messing it up. so in teh controller gui i typed in the file i wanted, but left the file location blank. only after this did the file transfer occur.. thank you for you help in this!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
