MPLS VPN SOO
Answered Question
Aug 11th, 2008
  • Gold, 750 points or more
How can i attach SOO to connected subnets without advertising it using network command?
regards
Devang Patel
Correct Answer by dara111983 about 8 years 9 months ago
HI Devang,
You can try using the
#Ip vrf Site-map ____
Interface config level command.
Reply back if it solves!
Dara
Overall Rating: 5 (2 ratings)
devang_etcom Mon, 08/11/2008 - 10:40
above post is related to the BGP configuration not EIGRP.
lee.reade Tue, 08/12/2008 - 06:21
  • Silver, 250 points or more
I am not able to test this myself but, if you are redistributing the connected routes into BGP then in the redistribute command, call a route-map and use the "set extcommunity soo"
I dont see why this would not work.
LR
Correct Answer
dara111983 Tue, 08/12/2008 - 11:25
HI Devang,
Dara
lee.reade Wed, 08/13/2008 - 05:17
The interface site-map configuration is specific to EIGRP use and not BGP.
LR
dara111983 Wed, 08/13/2008 - 05:47
Hi Lr,
You are right, but it would still work.
However I guess the solution contradict with the requirement of adding the network statement.
Dara
devang_etcom Wed, 08/13/2008 - 11:55
Dara,
thanks for your reply... and yes it worked for me with ip vrf sitemap... and it attached SOO to interface prefix...
Here is my config and show output for the same...
router bgp 99
address-family ipv4 vrf ABC
redistribute connected
route-map SOO permit 10
set extcommunity soo 99:99
interface Loopback99
ip vrf forwarding ABC
ip vrf sitemap SOO
ip address 99.99.99.99 255.255.255.255
end
R99#show ip bgp vpnv4 all 99.99.99.99
BGP routing table entry for 1:11:99.99.99.99/32, version 8
Paths: (1 available, best #1, table ABC)
Advertised to non peer-group peers:
150.1.2.2 150.1.7.7 150.1.8.8
Local
0.0.0.0 from 0.0.0.0 (150.1.9.9)
Origin incomplete, metric 0, localpref 100, weight 32768, valid, sourced,
best
Extended Community: SoO:99:99 RT:1:11,
mpls labels in/out 22/aggregate(ABC)
thanks & regards
Devang Patel
