ahmed_saleh Mon, 08/11/2008 - 11:04
Ok thanks but I need to tell you my router have tow interfaces
S1/0 connected to ISP1
S1/1 connected to ISP2
ISP1 support us with 6MB
ISP2 support us with 8MB
I need to aggregate 6MB+8MB = 14 MB
And I have 1 ip in each Serial interface I can't use virtual template interface or Interface Dialer
Did you have anther solution?
Giuseppe Larosa Mon, 08/11/2008 - 11:18
  • Hall of Fame,
    Founding Member
Hello Ahmed,
in this case I would suggest to use load-balancing at layer 3 but Bandwidths are different on the two links.
You should use FR subifs 4 on link 1 and 3 on link 2, then increase the maximum-paths to 7 on your routing protocol (if possible)
Otherwise you should use EIGRP with variance for unequal load-balancing but I don't think you are using it with your providers
I don't think you can aggregate them.
What routing protocol do you use with your two providers ?
Hope to help
Giuseppe
ahmed_saleh Mon, 08/11/2008 - 11:24
Ok I will drown my network now and I will post it for you again
ahmed_saleh Mon, 08/11/2008 - 12:34
Sorry I am running dynamips to share what I will do this is not a rally configuration
________________________________________________________________
Rack1R2(config-subif)#do show run int f 0/0.1
Building configuration...
Current configuration : 194 bytes
interface FastEthernet0/0.1
encapsulation dot1Q 10
ip address 192.168.1.2 255.255.255.0
no snmp trap link-status
standby 1 ip 192.168.1.254
standby 1 priority 150
standby 1 preempt
Rack1R4(config-subif)#do show run int e 0/0.1
Current configuration : 147 bytes
interface Ethernet0/0.1
ip address 192.168.1.4 255.255.255.0
1 then I will configure anther 2 vlan like these steps
2 I will configure NAT
3 it's the critical point for me aggregation the link in tow serial interface in eche router
4 if you have complete configuration please post it for me
Giuseppe Larosa Wed, 08/13/2008 - 06:17
  • Hall of Fame,
    Founding Member
Hello Ahmed,
if you need to use NAT the best strategy is to use two pools one provided by ISP1 and one used by provider2.
At the routing level I would suggest to use the slower link as a backup.
hope to help
Giuseppe
ahmed_saleh Mon, 08/11/2008 - 13:31
please I need response about this configuration just I am use this to share what I will do in the network I am not share a task for study but I will make this configuration in real environment
Giuseppe Larosa Mon, 08/11/2008 - 10:50
  • Hall of Fame,
    Founding Member
Hello Ahmed,
the most common option is multilink PPP
you can follow this example:
int ser1/0
no ip address
enc ppp
ppp multilink 1
int ser1/1
no ip address
enc ppp
ppp multilink 1
interface multilink1
enc ppp
ppp multilink 1
ip address x.x.x.1 255.255.255.252
the configuration needs to be replicated on the other side's router using x.x.x.2 as the ip address.
use the following link as a reference
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/mlppp_over_serial.html
Hope to help
Giuseppe
