Unable to populate DRC
Aug 11th, 2008
I believe that I am correctly placing the seed device, I run a discovery and get 0 number of devices discovered.
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 08/11/2008 - 11:23
Please post your NMSROOT/conf/csdiscovery/CSDiscovery-config.xml as well as your CSDiscovery.log file.
ciscopatmcnamara Mon, 08/11/2008 - 11:42
Will I have these files even if I used CDP and tried to designate a seed device. Thus far I am doing a search for the first file with no success.
Joe Clarke Mon, 08/11/2008 - 11:53
If you have Common Services 3.1.1, then you should be using Common Services Discovery, and you must have the CSDiscovery-config.xml file.
Joe Clarke Mon, 08/11/2008 - 11:56
The config file is the most important. Note: NMSROOT is the path into which you installed LMS.
Joe Clarke Mon, 08/11/2008 - 12:54
Your IP range only allows two devices to be discovered: and I think what you meant was something like the following:
Your seed device of 143.79.*.* is also invalid. Just delete that seed. Seed devices should be absolute IP addresses.
