Administrator and Active Directory authentication
Aug 11th, 2008
Hi all,
A simple question: is it possible to use Active Directory authentication for Ironport administrators?
I am using a C-150 appliance with v6.1.0-306.
With best regards :wink:,
verylongbloke_i... Mon, 08/11/2008 - 13:29
Sadly not today - but this is a roadmapped feature for the email security appliance to come in the future though :)
David.shoesmith73 Fri, 08/22/2008 - 00:40
This feature will be available in future releases. I am currently beta testing it and can say it works rather well.
I would also recommend you update your AsyncOS as well.
There are some major bugs in the version you have that you should try and avoid.
arcastor_ironport Fri, 08/22/2008 - 13:28
Thanks for help Bogor,
I know I have to update it but I just come back from long vacations. Update is planned for next week ;)
