Daniel Voicu Mon, 08/11/2008 - 23:06
On the ASA the VPN tunnels are created by matching a specific access-list (source, destination, ports).
Can you elaborate a bit what you are trying to achieve?
Daniel
r-barbosa Tue, 08/12/2008 - 06:42
Hi Daniel,
I'have a IP phone in a remote site, but the generated packets created from the remote site using the IP phone did NOT create the VPN tunnel, only the packets generated by the PING command... any ideias?
regards.
Farrukh Haroon Tue, 08/12/2008 - 11:37
Can you post your configs? Specially the Crypto ACL?
Cisco IP Phone (SCCP /SIP what protocol?)
Farrukh
r-barbosa Tue, 08/12/2008 - 12:46
hi
my settings
ipsec - site A
crypto map outside_map 2 match address outside_cryptomap
crypto map outside_map 2 set peer 201.10.10.10
crypto map outside_map 2 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
acl - site A
access-list outside_cryptomap extended permit ip 10.0.2.0 255.255.255.0 10.0.1.0 255.255.255.0
ipsec - site B
crypto map outside_map0 2 match address outside_cryptomap_1
crypto map outside_map0 2 set peer 202.10.10.10
crypto map outside_map0 2 set transform-set ESP-3DES-SHA
crypto map outside_map0 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map0 interface outside
crypto isakmp enable outside
acl - site B
access-list outside_cryptomap_1 extended permit ip 10.0.1.0 255.255.255.0 10.0.2.0 255.255.255.0
The protocol is H323.
regards.
Farrukh Haroon Tue, 08/12/2008 - 18:21
Configuration seems OK. Do the following;
debug crypto isakmp 127
debug crypto engine
And then the following (on both sides)
clear crypto isakmp sa
clear crypto ipsec sa
Then initiate the voice traffic and see if VPN kicks in.
Is there any NAT? how is the NAT 0 config look like?
Farrukh
