What is the newest CCME I can put on a 2801?
Answered Question
Aug 11th, 2008
I look in the IOS Cisco Feature Navigator and found the the highest it would support is
CallManager Express 4.0(3)
is this correct?
I also was hoping to buy a 512MB CF card from the store a putting it in the router will it support more then 128? the hardware specs say 128 but its just a CF card?
Correct Answer by Chris Deren about 8 years 10 months ago
The latest CME is 7.0(1), which jumped right from 4.3
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeroad.html
You cannot use the non-cisco CF in Cisco routers. You can get them to work if formatted properly, but they will not be supported.
HTH, please rate all posts!
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Mon, 08/11/2008 - 13:55
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Chris
johnakeating Mon, 08/11/2008 - 16:22
So.... They work then if you format them correctly this is just for a lab anyways nothing production...
and by supported you mean cisco would not have anything to do with it correct?
Chris Deren Mon, 08/11/2008 - 16:28
  • Hall of Fame,
You got it!
Chris
