static route not being added to routing table
Aug 11th, 2008
I have an 1841 with a WIC-1ADSL-DG and am using Port Address Translation and I recently added a HWIC-4ESW etherswitch card. I have a class C address assigned to the default vlan and a different class C address assigned to f0/0. The problem is that when I went to add two static routes so that computers attached to the etherswitch card will be able to access the lan on f0/0 and the internet, the static route to the vlan did not show up in the routing table.
The following are the three routes that I have in my config file:
ip route Dialer1
ip route x.x.x.0 f0/0
ip route x.x.x.0 vlan1
the last route is the one that would not show up in my routing table. As result any computer attached to the etherswitch card (vlan1) can ping any computer attached to f0/0, but will not go out on the internet.
Marwan ALshawi Mon, 08/11/2008 - 16:14
first why u need to creat static route for vlan1 and fa0/0?
do u have any other router connected to those interfaces?
if not i mean only hosts connected to those ports u dont need the static route
once u creat the vlan interface
it show show u as a directly connected interface
and a bout fa0/0
u can also creat another vlan interface and make fa0/0
part of it
the following link will guid u step by step to configure ur etherswitch
good luck
please,, if helpful Rate
rtw00ten1 Mon, 08/11/2008 - 16:28
Whenever I try to assign vlan1 an IP address that is on the same class C as fa0/0, it gives me the following error:
"% x.x.x.0 overlaps with FastEthernet0/0"
It will only accept an IP address that is on a completely separate class C, there for I need to add some static routes if I want the vlan to be able to access the fa0/0 lan and the internet.
Marwan ALshawi Mon, 08/11/2008 - 16:40
ofcourse u cant
u cant have two routed interface with the same subnet range IPs
lets say the following example
interface vlan 1
ip address
interface fa0/0
ip address
in the above example u will get anerror same to what u are getting now
so to solve it
interface fa0/0
ip address
now u have put interface fa0/0 in deffrent subnet and will work normaly
good luck
if u need any more details just post here :)
please, if helpful rate
rtw00ten1 Mon, 08/11/2008 - 16:49
No it won't. That is what I'm doing now and the problem is that then vlan1 won't have access to fa0/0 or the internet without adding some routes to the routing table. If you read my original post you will see the problem that I'm having in adding those routes to the routing table.
lamav Mon, 08/11/2008 - 16:59
Please post the entire config and, if possible, do not "X" out the addresses. If they are private addresses, you dont have to X them out.
Richard Burts Tue, 08/12/2008 - 04:08
Victor is correct that it will be easier to resolve this if we have the complete config to look at. It would also be helpful to have the output of show ip route.
When a subnet (or network) is assigned to the VLAN interface it should show up in the routing table as a connected route. And a static route for the same prefix should not show up in the routing table. I suspect that this may be why the static route for VLAN 1 does not show up. I am quite curious about the static route for F0/0. The original post seems to imply that this static route does show up. I wonder if that is really the case.
Giuseppe Larosa Wed, 08/13/2008 - 06:13
Hello Rafe,
you had your router configured and working and then you added an etherswitch.
If you want to provide internet access to the etherswitch's ports users in vlan 1 what you need is :
a change on your NAT rules so that also source addresses of VLan1, that cannot be the same as int f0/0 as noted in previuos posts, can be translated when going to the internet
you don't need static routes on a single router to route traffic between connected interfaces
Hope to help
rtw00ten1 Wed, 08/13/2008 - 08:39
Thanks, but I acutally got it working last yesterday. As it turns out, it was a problem with NAT. Althought the class C that I have on the vlan interface still isn't showing up in the routing table for some stange reason. But, I don't care anymore because like I said, I got it working. :)
NewBloke01 Wed, 08/13/2008 - 06:36
Wouldn't it be better to take the IP address off of the physical port and put the F0/0 interface into VLAN1? That way you won't need to route, you just assign the IP address of (say) to VLAN1 and make F0/0 in VLAN1.
Is this a bit simplistic? Have I missed the point?
Giuseppe Larosa Wed, 08/13/2008 - 08:37
Hello Tim,
this can be done or not depending on router platform.
int fas0/0 is a router port and expects to have an ip address.
I can put int fas0/0 and vlan 1 in the same bridge-group and then I can assign the ip address and the ip nat inside to the BVI interface (the L3 interface of bridge-group using integrated routing and bridging).
I'm not sure that is possible on a router.
In other words I suppose that:
int fas0/0
(1)switchport mode access
(1) switchport access vlan 1
can be rejected by the CLI
I would suggest
bridge 1 route ip
bridge 1 protocol ieee
int fas0/0
no ip address
bridge-group 1
int vlan1
no ip address
(2) bridge-group 1
int bv1
ip address x.x.x.x
ip nat inside
but I'm afraid that (2) could be not accepted.
Solution 1) that you have suggested could work on a C870, but here is using a C2600 or more, because it has inserted an etherswitch module.
In this kind of platform I think switchport commands are accepted on etherswitch's ports only, but I may be wrong.
On the other side I used inter-vlan bridging on a C3550 and I don't know if here it is allowed (command (2) above).
So the answer is that your solution can work but it should be tested.
In theory is a good solution. In my previous post I wanted to move focus on NAT because it is that feature that allows to go to the internet.
The router routes between connected L3 interfaces without any need of static routes
Only the default route out dialer1 is needed here.
Hope to help
rtw00ten1 Wed, 08/13/2008 - 08:42
I've had others give that exact same suggestion, but I just can't stand wasting a port on the etherswitch by doing that, but it really dosn't matter any more because I got it working the way I wanted yesterday. :)
Giuseppe Larosa Wed, 08/13/2008 - 08:51
Hello Rafe,
nice to hear you solved your issue
May I ask you what you have done to have it working ?
Best Regards
